Weird Blinker Issue On 03 Silverado
The passenger's side front turn signal alternates between the large amber bulb and the small amber side marker just like it should. However, when I use the turn signal on the driver's side, only the large amber bulb blinks and the side marker just stays lit. Any idea what might be causing this?
I vote harness has a short in it
Usually it is a bad bulb or the bulb socket has moisture in it, causing bad contact. Using dielectric grease in the bulb sockets helps.
