Elegtrical Gremlins?
1low1
HI all i'm new here because i NEED help. I have a 2003 silverado 2500HD 4x4 6.0l . I just bought it so i have little history. When i firts drove it the speedo needle jumped arounf occasionally and the tranny would not shift properly when the needle did this, also the ABS and EBRAKE lights came on. I changed the speed sensor and everything seemed fine for a day. I parked it with everything working and pulled the driveshaft for a few days re-installed it and now i have the ABS and EBRAKE lights no speedo at all and it shifts fine (although slightly hard) Also my ODOMETER work fine prior to speed sensor change and after but after driveshaft change nothing. Any help would obviously be aappreciated.
Ok i was able to get my buddy to pull afew codes they are, C0055 an ABS code, U1000 class 2 data link fault IPC code also a Body code? B1440 hopefully these will help you help me!!
