Recommendations For Exhaust
Hey all,
I think the first thing I want to do to my truck is a catback dual exhaust. I want one where the tips exit to the side right after the rear wheels with some nice meaty tips.
I don't feel like dropping 500 on an exhaust for this truck, so does anyone have any recommendations? I want a nice aggressive tone, loud but not too loud.
What kind of gains can I expect and are shorty headers worth the money?
Any ideas?
Thanks!!
Do a search there a hundreds of treads of exhausts and videos you can listen too. Corsa, Magnaflow, MBRP and Gibson are just a few.
I got a gibson super truck exhaust on my 09 silverado. I paid around $400 for the stainless but u can get it in aluminum for like 340 (make sure u paint the aluminum one to seal or it will rust, had that problem on my old ram). Great sound too.
I also installed Gibson's on '05 Suburban. Louder, but not too loud. I went with Gibson's because theirs was the only website that had a graph showing an actual power gain with their product.
If you have the cash ...Hands down the Corsa exhaust. No drone inside the cab. Awesome sound inside that you get a nice rumble even when towing. And I feel it flows the best. Great clamps extra wide if your not welding it. Stainless...just awesome exhaust! Also, it gets people looking without annoying them. I can't stand my neighbors Flowmaster, it wakes me up every night he comes home from the bar! Well JMO...good luck!!
I went with a Magnaflow single in/dual out setup. I got it installed pretty cheap since they used the stock 3" pipe to go from the cats to the muffler. The reason that I went with Magnaflow instead of Flowmaster is because Magnaflow is a straight through design and they are stainless. My research showed me that Flowmasters don't flow good at all. I like the sound of the Magnaflow since it isn't too bad on the drone inside of the cab yet it still has a deep, loud rumble. Personally, I am a huge fan of true dual straight pipes! This is the first time that I have used a muffler on a truck (thanks to the great state of CA).
i'm cutting out the muffler and putting in a piece of stainless pipe, sounds great here's a youtube clip
http://www.youtube.com/watch?v=uA7Us4fTwEc
resonators, plus cat, and long plumbing is muffler enough
i had a 305 with a mild cam in a 78 monte, 1"5/8 primaries to sidepipes, sounded good. too bad it sounded tougher than the boat anchor it was.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
