Open The Door On 2010 Gmt900 And Snow Falls In!
Maybe place a tarp or something over the top of the truck and the door so in the morning you can just pull it off. Just finding something that wont scratch the paint will be the hard part.
  • Replies 33
one thing that I've found to help this (if you have a crew cab) is open the rear door first, then slowly open the front door. of course, try to brush off as much as you can before opening any doors. I think it's the vacuum, or draft, that's created when you open the door that swoops some snow onto the seat. by opening the rear door (you'll get snow back there, but at leat you're not sitting on it) that breaks the draft effect on the front door. I don't know, but for me it works. of course if you've got an extended cab or regular cab ignore this, lol!
Unreal what some people complain about. All vehicles do this unless they design a vehicle that the roof hangs over the door sills.
I'm not complaining, I'm more concerned with long term effects on my seats and other internal parts. Thanks for the replies guys. After reading I don't believe I'll have many problems with this. Just have to brush before getting in where possible.
Yup, not much you can do about it.
One of the benefits of living in a place with 4 seasons! :shakehead:
This happened for 9 years with my 2000 and I had no issues. Just brush whatever falls in off
Yep, Unless you have a giant umbrella, garage the truck, or live in a climate that doesnt snow this will happen with every vehicle. Surprising, it also does it when it rains too go figure..... :shakehead:
I am not complaining because it is my own dumb fault, but I always kick myself in the butt when I do this: Park truck at night after driving with the wipers on, forget to turn them off. Next morning go out to warm up truck, covered in a few inches of snow), open door and just reach in to start truck with door still open, wipers kick on swishing all the snow that was on my windshield into my cab, door panel and seat. Grrrrrrrrrrrrrrrrrrrrrrrr.
I do this 5 or 6 times a year, too. I do not learn.
I do this too in the winter time. Pain in the ass! :lol:
What's worse...Leaving the wipers on and coming out the next morning and there's 1/2" of ice covering the whole truck...Start it, wipers kick on, wipers DON'T MOVE, strip out the wiper :)
I've done this TWICE now. :cheers:
  • 3 years later...
My 2013 and 2003 Silverados both have this issue of snow falling onto the seat when you open the door. This morning I had a wet butt on the way to work due to snow falling out of the top door groove onto the seat. I swept it with the brush but still got wet.
I hear the 2014 truck doors no longer wrap up over the roof - they indent into the roof like they used to many years ago. I wonder if that cures the issue?
Holy thread resurrection. This has been gone over like 30 times.
The new trucks aren't any different in this aspect. Just like always, take your hand or snow brush and brush the snow off the door jamb! Maybe you didn't brush hard enough or something, lol. There's really no solution.
I was thinking the 2014s might stop this too to some degree, since their doors are completely recessed. I'm betting the old square bodies weren't quite as bad about this as they had some serious gutters. Sometimes I miss those gutters, like when I have the windows down after a rain, go to make a turn, and all the roof water pours in on me or my passenger (depending on direction of turn).
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
