What Type Of Fastener Is This?
It looks like this is a steel pin with its end mushroomed out to stay in place. You will probably need to grind off the mushroomed part to get it out.
That is a rivot. A really long one. Why do you need to remove it?
Replacing the latch on my glove box. However, the new latch I got had peeling paint so, I'm going to still use the the cover from my old latch.
This "rivet" is about 1/16" in diameter and 1 3/4" long. Where can I get a new one?
Where do I buy a new pin and how do I remushroom the head?
I had to take mine apart too because the spring broke ant it rattled. I cut the mushroomed end off with a dremel and used a long bolt and nut to replace it. Works great. It was just a bolt from my junk box. Don't know the size, sorry.
Drill it out and replace it with a long screw and nut.
its a long ass rivot big 10-4 on the replacing it with a small bolt/lockwasher/nylock
It looks like a proprietary rivet to me.l I doubt you are going to like the results if you take it apart. Why not scuff up and paint the handle?
There's a special tool used to flare the end of the rivet. There's an anvil that goes on the open end to form the flare and then a piece that fits on the head to allow you to smack it without ruining the head. When you smack it, the open end flares out.
    DWic
    DWic
  • Who's Online   3 Members, 0 Anonymous, 593 Guests (See full list)
