How To Check Battery Condition
What is the correct way to check for truck battery health, how many amp load for testing etc. or do you go to a dealer or parts shop and use their FREE testing offers? will they tell you the real condition of your battery or just try to sell you new one. thanks for any input
If you only have a voltmeter, wait 8 hrs after you last ran the vehicle and check for voltage. If it is 12.7V or better it is considered to be in good shape (all 6 cells making enough voltage). But that doesn't measure amperage output which is what you need to turn the starter motor. A load test is better because it measures the capacity of the battery instead of just the static voltage.
DEWFPO
+1 on the load tester. I've seen plenty of bad batteries show 12-14 volts until you hit that load button, then they drop to almost nothing.
Use A hydrometer if you don't have a seal battery to measure the specific gravity of each cell, this will tell you real quick if you have some bad cells...As mentioned above a battery can show good voltage but may not be able to carry a load due to dead cells.
You can do a load test by putting your volt meter on the battery, then crank the starter. Watching the meter before the engine starts the voltage should not drop below about 10.5 volts.
The voltage only tells half of the story. I've seen a battery at my job holding 12.6 volts that only had 175cca. The battery was rated at 625cca. You need to have a load test done or have it tested with the newer electronic testers at the major auto stores.
Mike
Good Idea
I found for sale a 50amp and a 100amp load tester.does anyone know which is the correct amp rating for GMC truck battery or none of them? or what should the amp rating be for testing. Thanks
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
