Gmt800 Oem 17" Rim Issue
I dont have pictures of my issue (Yet) but I noticed this issue this weekend while working on the truck. I noticed that the surface of my rims in certain areas have spots on them. I cleaned them and recleaned them with water and 10 (literally) microfiber pads. No soap was involved as I figured it was something light, maybe dirt or light brake dust. No dice on the removal of the spots.
I need to know if these rims can be refinished and reclearcoated without damaging the structure.
Here are the OEM Styled P25 rims:
The above pictures only represent the style rim I have installed. They are not the ones that are "damaged".
What I need to know is:
1) Can these rims be refinished back to the stock look?
2) Is there an approved refinisher in Austin?
3) Am I stuck with getting new/replacement ones?
If you have any thoughts on how I should go about handling this, I would appreciate it.
Mike
Mike,If their the kind of spots I think your describing...try a little hand glaze.
Some of the wheels on my previous trucks would get these "light white",or "hazy" spots on them,a little 3M hand glaze,followed up by a coat of wax and they were fine!
Your aluminum wheels are clear coated.....the metal underneath is oxidizing causing the white finish between the clear and the rim. Using wax might slow it down, buy sealing the clear coat....most likely a rock chip hit hard enough to penetrate though the clear. Not much you can do other than getting it stripped and re cleared....its cheaper to buy aftermarket wheels r newer take offs.
The same thing happens when wheel weights are installed on the dedge of the rim...it scratched through the clear and causes oxidation. Its a pretty slow process though and most people won't even notice it.
Ask to "bubble balance" your tires, the weight will be on the other sode of your rim where you won't see it oxidize.
Oh and I can't even see the imperfections in you pics. Even if you reclear coat its going to do the same thing in a couple years. After these rims are designed for a vehicle that is to be used, not stored to show car perfection.
If it is the problem I think you are describing, there is not much that can be done. I have seen this problem with that style of wheel several times, typically surounding the wheel weights. The wheel weight punctures the surface of the clear coat and from there the moisture makes its way under the clear coat and begins to spread. The wheels on the White truck in my signature were replaced once under warranty for this problem. My black truck had the same problem when I bought it used and was unable to get it warranted and ended up getting the custom wheels that are on it now. I sold my white truck a few weeks ago when I ordered a new one, and noticed right after I sold it to a buddy of mine that one of the wheels was starting to go bad again. Same deal, it was starting to spread right by the wheel weights.
Mike
Aluminum wheel acid will do that if you let it dry......... I let a bunch of kids wash my other halfs Tahoe (before we sold it) for something (i think it was a school fund raiser) anyways. They RUINED the clear coat on the wheels. They were nice and shinny but covered in brake dust.
I walked down to where they washed it (like 2 blocks) and walked by it and was were is my Tahoe?? They said you walked right by it...... I did not say anything but I did see the acid bottle.... It got them clean...... I buffed them several times with Tripoli and white rouge... TO no avail.
Ended up pulling the tires off and sending them off to a wheel shop and getting the clear removed, buffed, painted, and cleared........ Other half was pissed... I was like were gonnna trade it in a couple months but no no no no no. Worked out good one of my friends bought it instead of us trading it.. I still have to see it soooo, I guess I was aight with paying for the rims to look good again. (I could have done it but was really busy then and did not have time)
Jbo
Man this is a bummer. Can you powder coat them the correct color so there will be no probelms later? These are the stock type of wheels i am looknig to get back on my 2006 4x4. this is not good news.
I found a set of new take offs from a 2006 with the factory tires on the rims. How do i know they are for a 4x4?
Did 4x2 have 5 lug and 4x4 have 6 lug?
No,All 1/2-ton GMT800/900 trucks are 6-lug,weather they are 2 or 4wd.
Ok, finally had a good day in which I took pictures of what I am talking about. I am not sure if this is what everyone else is referring to but this does not seem to have started near the wheel weights, rather it seems to just have appeared on the face of the spokes.
Edit: and no, these wheels are not scratched, that is exactly how they look in person but they are smooth to the touch.
Mike,Thats how mine looked (although not quite that bad) try some 3M hand glaze,worked on mine!!!
The clearcoat on these wheels is of poor quality. I have several short spiderwebs under the clearcoat on at least one wheel, and it originated form the center of the wheel, not the wheel balancing weight area. These types of clearcoated wheels corrode around here in coastal Florida, there is not much one can do about it, except refinish them. .
To remove that haze, you might also use a scratch remover car wax, such as KIT from the Auto Zone.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
