Whats Needed To Add Rainsense Wipers?
What's needed to add rainsense to an 07 Tahoe? I need to replace windshield anyway, does the rainsense need a special one and is there anything else to the system other then the sensor by the rear view mirror? I read that to disable rainsense you just unplug the sensor, so would plugging in the sensor enable it?
I don't have an answer directly for this, but I believe the turn signal stalk (that has wiper controls) is different also.
Not sure the connection is there and you need the software/controls and maybe new stalk...I think it would be a bit much...but not sure...note that some like rainsense and some do not...I think your brain and left hand work (ie you set the delay) better than the rainsense.
I have rainsense on my 07 Sierra and wish I didn't. I'm going to disable it soon. Maybe I'm too used to the manual delay, but the rainsense NEVER wipes when I want it too unless it is a steady rain, and then it normally goes to wide open when it does not need to. Also, if a little ice builds up over the sensor it doesn't work at all.
The stalk is the same from what I've seen. If the sensor is unplugged the 5 sensitivity settings revert back to the 5 delay settings. I don't so much care for the turning on part but the automatically varying speed. I towed from So Cal to Nor Cal in a rain storm and had to adjust the wiper speeds about 50 times going from light to heavy rain. My mother has automatic wipers on her Mercedes and they work wonderfully and I hope GM got it close
IMO the rainsense feature is annoying. It doesnt start most of the time when it rains (I have to hit the switch), then when the rain stops it keeps going....Its goes super fast when it doesnt need to....I like the timed intervals a lot better. Just my take on it :dunno:
Works great in summer (rain), works like crap in the winter (snow, sleet).
Why not have an on/off switch for it so we can choose?
That would be to easy to do. :dunno:
Hate to break it to you, but GM didn't. Rainsense is a USELESS feature -- you really shouldn't waste your money trying to add it.
Mine is disabled, and I like it MUCH better that way.
Can someone pls post instructions or a pic of where this sensor is on my truck so that I can unplug it to disable mine? Thanks!
On my 09, the connection is in the small box/cover behind top right mirror... pop off cover and just unplug..
Save your money. I agree with those above, most of the time it's a PITA. I find myself having to turn the wipers off and on. Sometimes they'll wait until almost you can't see before they come on. Then sometimes when it's just misting they want to go MUCH faster than needed. Knowing what I do now, if I didn't already have them I wouldn't get them if they were free. JMHO
Are you talking about your rear view mirror?
It may be just me, but I think the "rainsense" wipers is the most nonsensical option yet. The only thing dumber than this is probably a heated cup holder. :dunno:
Hey, I actually WANT a heated/cooled cup holder. The Escalade has them; I just have to figure out how to retrofit them into the console of my GMC :pimp:
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
