Everyone, I want your opinion on this. The truck is a 2003 RCSB. I had the oil changed in October of 09. Right now the truck has 39,871 miles on it. The dealer put in the window to change the oil at 39,866 miles. So I am just slightly past this, and my Oil Life Monitoring is at 18%.
I told the dealer to put 5-30 Mobil 1 Synthetic in it, and on the slip from the dealer it states they did. But from what I had read I thought the OLM system can tell the difference between dino and synthetic oil and would go down accordingly. So being at 18% right around the 3,000 mark shocks me some. Do you think the dealer put regular oil in?? I do live in Minnesota, so this could/would make the OLM go down somewhat faster, but I usually started the truck and let it warm up. I know the OLM system takes all that into account and the idle time, etc. I do drive about 15 miles to work one way and then home, so the shorter trips might be to blame. I had planned to run synthetic and then just change oil twice a year, every six months, and figured for what i drive that would be about right. I know its not near the mileage you can run on synthetic.
So what do you guys think, run the oil to 5,000 miles, or change here sometime in the near future? Thanks!
I don't think the O.L.M. can tell what kind of oil is in the truck. Someone might say I'm wrong though. :(
Are you planning to change it yourself this time, or have the dealer do it again?
Well I could do it myself I suppose, have before on my car. Just my 'nicer' vehicles i have always taken it to the dealer for them to service. I am tempted to take a sample of the oil and send it Blackstone Labs and have them analyze it, see what I get for results.
I know thats what the OLM system is there for....but still...I am curious if it can tell what type of oil is there or not.
I was just over at my friends house helping him move in a new safe he bought, and he has an 04 Duramax and I asked him if he goes by the OLM and he said yep, and then I looked at his. His has 45,xxx on it and the oil was changed at 42,xxx and he still has 65% oil life yet! Well mine is right at 3,000 and at 18% so what gives? I think i will schedule an appointment here before my Blackbear tune in April and have it changed and see. This is my first full oil change since i have owned this truck, and see who round two goes.
OLM has no idea what kind of oil (viscosity grade or dyno/synthetic) ... the computer monitors the number of revs in the engine, the time the engine is running, the temperature of the engine while it is running, and likely some other relevant parameters....
I assume that GM assumes that you will be using the specified dyno oil in your manual. so if you are using synthetic you might feel OK stretching out the oil change interval, but that is our choice.
Most people either have a specified mileage on the odometer to change or they wait until the OLM tells them to. My truck ('97) does not have one, but I don't put a lot of miles on it, so I make sure it gets changed in the spring and fall with synthetic (just my choice of oil). The OLM on my 2002 Impala used to light up somewhere between 9000 to 10,000 kilometers, and that seemed OK to me to change the synthetic oil..
Thanks for the reply, and from everyone else also. That makes sense then, why my friend's is different though i don't know, unless the Duramax has different programming which it very likely does. But I thought I would run the oil 5,000 miles since synthetic, or 6 months. Thats only 2 oil changes a year for me, so this is what i will be doing. This has been my daily driver throughout the winter, so now when i get my car out and motorcycle this summer, the truck will get less miles on it, so synthetic is probably a waste for me and the mileage i put on.
Duramax has a larger oil volume as well as a standard oil cooler. That undoubtably figures into the longer oil life. Duramax also turns lower RPM's being a diesel so there would be less wear to deal with.
There were 5 Duramax's at the company where I worked in construction and I changed the oil on all of them between 9000-10000 miles. This was recommended by the dealer and we thought he was nuts. We ran independent oil samples thru our oil supplier on every change and they always came back good and this was running in const. conditions. The diesel will have a longer life than the gas rigs but the new gas rigs we were running we could extend the change intervals over the older ones. Most oil suppliers and or dealerships should have access to the oil sample labs [at a small cost of coarse] and to put your mind at ease you may want to have a sample ran at different mileage intervals and this would tell you the maximum oil life that you have. Keep in mind to use the same oil and filter all the time because there is a difference in them and how long they can go.
No
From GM technical article...
NOTE: Synthetic oil resists "wearing out" better than mineral oil, so the oil life monitor is set to account for this, but only on vehicles that are specified for synthetic oil from the factory -- the Corvette, for instance. Using synthetic oil in other vehicles is certainly not harmful, but the oil life monitor will continue to count down as though the engine contained
mineral oil.
Thanks guys...Well I think I will get it changed here in April then, and just for the heck of it take a sample and send it off, since I got the free kit from Blackstone Labs.
I just need to decide to run syn or just go back to dino and change every 3k. In the MN winters though i think the syn would help. Thanks again though everyone, I appreciate it!
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
    • The top speed is software limited, I don't think there's a way to change it without de-doing the whole truck. If you can get a CAN log per my above post we can try seeing if there's anything obvious going on. What happens when you plug the truck in to charge it, does it ever fully charge up or does it stay at low battery %?
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  The factory spec would apply to the Moog bolts as well.    I see two things different.  The Moog bolts are greaseable (which I see no point in) and they don't have one of the washers welded to the bolt like the factory bolts, so they can be used in all 4 positions.      Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.  A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
