Gm Cargo Mangement System And
getting a spray in bed line on an CC silverado and I have the cargo mangement system in the bed, I already have the frame out but the attactment points that I screw into don't come out.
How does this work when they spray the liner? anybody have pictures of how thier's came out?
Thanks!
The clamps do come out.
Take the bolt out. Then pull on the clamp until the you feel the spring loaded part "click" into place. Then use a thin screw driver to rotate it so that one arm comes through the hole and it'll slide right out.
I know that doesn't make much sense now... but once you do it once it'll make total sense :(
Edit: I recommend doing this on one of the front bedrail mounts first so that you can see what you are doing in the stake pocket.
Are you putting the rails back after the bedliner? If so why take them out at all?
Yes, took them out so the application of the bedliner would cover all area's. Put the rails back in afterwards.
Mine Line-X dealer pulled my rails for my Line-X installed and didn't charge me any extra to do it. They only removed the rails and the (bolts of course). Put a little tape over the hole so as not to get Line-X in the threads and that was it. Didn't removed the toggle bolt or nut part or what ever you would like to call it. I wouldn't bother removing them. Just let them know not to plug the threads. My dealer even re-installed them, but I did have to go around and tight things up a day or two later, I think they didn't want to over tighten until it had a chance to fully cure.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
