Factory Xm Radio Not Working
I subscribed to xm radio and am having the following problem:
After "refreshing" and going through all the steps XM said- the radio still would not update the channel list. - So I only get emergency alert and channel one.
Any ideas? should I look for a new XM module?
I take it you JUST subscribed very recently. I have had several different xm subscriptions and they have been notorious for being slow as anything activating radios. Give it some time, couple hours to a day.
No, I tried a year and a half ago- we tried for weeks to get it working. I'm just now wanting to get it working for good.
No help from XM or the dealer... they are doing the finger pointing game.
If you are picking up the emergency channel, then I would believe it is on their end. If your equipment was faulty, you wouldn't pick anything up.
X2
Definitely on XM's end. Are they billing you?
X2
They did for a month with me calling at least 2x a week. They would always try to send a refresh signal which never worked. Back during the elections I also got Potus 08- that's all though.
This bites because they are saying that it is the equipment, and GM is telling me its XM. Maybe I should just try again.
Ask to speak to a supervisor at XM and tell them you will be happy to put them in touch with a supervisor with your Dealer. For my truck, I had to have the truck on for about an hour (run position or engine running) after they sent the activation signal before it got it and everything loaded up.
X2
Welcome to the club, my saga has gone on since october. The indian guy at XM said it was the radio, chevy says its XM. I gave up, never had these issues with sirius.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 304 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
