Excessive Soot On Tailpipe
So I've got 12k on my 09 with the 4.8. I have noticed lately there is an excessive amount of black soot on my tailpipe. It's also on my right rear quarter panel (not too excessive, but there is a dark gray haze). Has anyone else had this happen? I haven't seen a code, however, I don't remember seeing this much on other cars I've owned unless it had a lean/rich fuel mixture. Is this something to keep an eye on or am I overreacting?
The truck seems to run fine, except the very very slight roughness that I've heard of on many of these trucks.
I've noticed the same on my '09. I don't know what is normal as my last truck was on propane- cleanest tailpipe you ever did see. I sometimes wonder if it is due to a crank position sensor issue that I had, which the dealer only cleared the code. This truck is a pig on fuel in the city; 14 MPG on the last tank and driving within the speed limits and no rapid launches at the lights, personally I think mine is running too rich.
Not like the old days with a clean tail...I had the same worry and talked to dealer, favorite shop etc...normal for black on tail pipe end...check some other new trucks and you will see same...?? Talk to dealer if good shop...
14mpg all city driving is about right..city driving has a lot of idle time at lights etc...I get 17.4 on about 50/50 city/hwy and about 18.5-19.5 hwy at 70-78 mph...
Man how ironic, I just noticed excessive soot in my exhaust as well in the past three weeks. I just put on an AFE cold air intake along with my lift and 35’s. I already had been running a corsa sport tuned exhaust and Diablo Sport Predator set on the 93 octane tune. It had been running pretty clean up until now. I even had it on a dyno when the exhaust and Predator where installed and the tuning guy said all the air/fuel mixtures were right on. It’s like it’s running too rich now, however my gas mileage is staying around 15 mpg (50/50 mix) even with the larger tires. Not sure if it’s the CAI, running at lower RPMs with the larger tires, or a combination of the two. I’m going to see if I can find a dyno wide enough in town to fit my tires to see what’s going on.
Thanks for the replies guys. Wonder if it has anything to do with the ethanol being added to gasoline?
Well, the 35's will bog your engine down at low cruising speeds, engine will be less efficient at pulling in air, but still needing the same amount of fuel to maintain speed. This might cause you to be rich and cover your exhaust in carbon.
Gentlemen,
Sooty exhaust can be the normal result of cool, damp weather. My exhaust is dead gray and dry but I live in a warm climate. Short trips can also contribute to a sooty exhaust.
Your fuel mileage should be checked. You might also change the front oxygen sensor if it really bothers you. As they age, they drive the mixture richer.
May not be a problem but keep an eye on it. Often, replacing the o2 sensor is cost effective for the above reason if over 100k miles.
Ken
Gentlemen,
Ken
We did have a really cool winter with a lot of precip. This may be the cause of it.
Every GM truck I've ever owned had this "problem". It's mostly due to the weight of your right foot, but it's not really any sort of malfunction.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
