What Gears Would You Recomend?
I have a 2006 crew cab with the 4.8L engine, it currently has 3.23 gears (according to RPO code GU5 in my glove box).
I plan on getting a total of 5" lift through a combination of CST and Fabtech parts. CST 4" spindle and 1" Daystar spacers in the front, 1.5" block (maybe 2") and 1.5" Fabtech add-a-leaf to the rear. I already have four Fabtech shocks on the truck.
I'm trying to emulate this persons truck that I found on the CST website, here's a link with some pictures and more info:
http://www.cstsuspension.com/gallery/?phot...otoGalleryID=75
This truck is my daily driver, I don't do very much heavy towing or hauling (I don't even have a tow hitch on the back!) The only off road driving I do is when we go out to the desert to shoot, and that's just dirt roads the whole way.
I plan to regear and add a Tru Trac at the same time, but I was wondering what you all would recomend for a gear size???
I have not yet decided on a wheel and tire size, I'm thinking of getting either a 33" tire with 17" wheel or a 35" tire with 18" wheel. I haven't decided because I am not yet 100% sure a 35 tire would fit with out any rubbing or trimming.
thanks
I have a 4.8 that came with 3.23s. Switched to 3.73s, running 33 inch tires. Perfect! 4.10s would have been too much.
my 2001 has a 5.3l with 3.73`s and I run 35`s, definitely took away from power, 4.10`s would put me back to stock but I`ll probably go 4.56`s as I do heavy hauling, if you`re going 35`s I`d go 4.10`s if you don`t pull a trailer.
that's a tough one... on my 2003 4.8L truck with stock tires it came stock with 3.42's, I went with 3.73's and improved in town mileage (easier starts in traffic) but lost a little on the highway of course.
You are going to a bigger tire, I would say go with the 4.10's unless you are doing a lot of highway driving (60+mph).
If you are doing a lot of highway travel 3.73 will be fine and help with mileage over the 4.10's.
If you are doing a mix.... there are 3.90's available lol
either way, you are on the right track.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
