Wheels Coming...thinking About Going With Slightly Bigger Tires...
Ok guys so I've been going back and forth on putting OEM 17's on my truck instead of the 17" moto metal 951's that I bought right after I got the truck. Well after almost a year of the moto metals with non-stock offset and bfg all terrain combo beating the body of my truck to death and looking at options to stop that I've decided to go back to stock wheels. I had the steel wheels on my truck when I bought it and just hated them so I rushed myself into making a decision on wheels and should have taken more time to find wheels that had an offset closer to stock but live and learn I guess. So now I am thinking that I'll go with a bigger tire (285/70/17) instead of the 265's I have now. Even with a level kit the 265's rubbed because of the wheel offset! But now that the tires will be back under the wheel wells fully I will probably go bigger because most guys here run 285's without issue on stock wheels. I really like the BFG's but I think that without the offset the 265's will look to small with the levelling kit....or not lol not sure. Just looking for some opinions. Thinking about a mud tire or one of the more aggressive A/T's. Any recommendations?
as far as mud i have the cooper stt's now and like them in nearly every way, except the noise. they are long wearing and aggressive tires that arent too heavy. now i need to say that i just orderd a set of bfg at's last friday to replace the coops with, so that may not help you much. you could get 40,000 miles out of the coops with good rotations and balancing, but if you get behind on those things on any mud tire you can count it out. if they get out of balance bad and you try to put one on the front you cant hardly steer it, it will wobble and shake, so use good maintenance, and buy a good mud tire, not a cheap knockoff. the toyos are supposed to be a little quieter and last longer than the coops but i cant verify that.
    Aries68
    Aries68
  • Who's Online   5 Members, 0 Anonymous, 485 Guests (See full list)
    • Check the windshield washer reservoir bolt. They ALL are loose from the factory.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
