New B Here
my07chevy
I just joined today April 12th. I'm looking through the site right now. Lots of info and useful stuff for everyone.
I have an 07 Silverado with a 6in Fabtech lift on 35x12.50x17's right now. Aftermarket DVD and navigation system in the dash and 2 8 in TV monitors in the headrests. I am currently shopping for 20 inch wheels and tires. I will be installing an AFE or Volant air intake here soon too. I will also be installing a new stereo system that we just put together. I will be running 4 10's or 3 12's (Crossfire) behind the seat with a 1000 watt Crossfire amp to run them along with replacing the factory door speakers with new component tweeters and a 400 watt amp to run them.
I look forward to reading the posts and posting some of my own here..........
Mike D
Post up some photos when you get a chance :lurk:
+1 ^^^^^^^^^^^^^^^^^^^^^^^
Welcome to the site.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
