Zero Rate or Helper Springs?
My 95 K1500 has the typical GM rear end sag going on.  Would my money be better spent on some helper springs or a zero rate add a leaf kit?  Or perhaps both?
  • 1 month later...
What I did was to add a extra leaf on each side(a friend had some lying around)that brought the back up 1.5",didn't have to drop the rear to do it either,just remove the two u bolts and the leaf centering bolt and shove it in and bolt everything back up.
   steve.
  • 4 weeks later...
I would go with adding a spring to your main spring pack...
Yes they will add to your sprung weight and make the truck ride a little worse, but it's a truck...
Contact overloads are fun to install, cost $$$, and only help you when your rear-end it already on its way down... resulting in a better ride..
Hellwig helpers I haven't seen or messed with so no comment there.
Air bags are always a good way to go...but there is maintenance involved...but they are unsprung with no air and are adjustable to your weight your carry..
  • 4 weeks later...
Delray, was wondering what the springs were out of that you installed? Is there an aftermarket add a leaf that would lift the rear 1.5" and not just help after it starts to sag? Thanks for the info guys.
  • 2 months later...
If Your up to spending the money, a new or lightly used set of 3/4 or 1 ton springs may be a viable solution.  I have done this to several 1/2 ton trucks and have been pleased with the results.
