Milling Down The Rc 2" Leveling Kit
I was thinking about having my RC 2" Leveling Kit milled down some so it was only an 1 1/2". I was wondering if anyone has done this and has any pics of what it looked like afterward. I was also wonering if anyone knew exactly how much to take off of the block to make it so it only gives you 1 1/2" of lift. Im pretty sure those blocks arent 2" thick to begin with.
I have one of the older RC kits on my truck. It was 1 - 1/2" thick plate, and 2 - 1/4" thick plates, to make any combo of 1",1 1/2", or 2" lift.
That would mean yours should be 1 inck thick, and you mill off 1/4" to make it a 1 1/2" lift. Ie... the plate thickness should be 1/2 of the total lift you want.
Or, you could just try to find an older kit and save the milling.
C
PS. The older kits were steel. I do not care for the newer plastic ones. Also, anyone with a tracer torch could easily make duplicates of the old type kit.
I just milled my plastic RC blocks down to 1/2" this week. I will be installing them wed or thurs night. I currently have 3" of rake from the factory.
I didnt want to raise the front too high, so I decided to mill the blocks to a 1/2" which should bring my front up about 1"
I then plan on milling the rear factory blocks down 1" (they are 1.25") to bring the rear down 1".
So in the end my truck should look more level and still have 1" of rake.
I will post pics later this week.
I bought a 1.5" kit off ebay, aluminum, so most would probably not want it. I have had it for months now without any issues. The spacer is 3/4" thick which gives the 1.5" of lift. From what I have read and researched the RC kit is an 1" spacer. So in my opinion just mill a 1/4" off and you got it.
Correct me if I am wrong guys!
Im thinking you guys that have said to take the 1/4" off are right. Im thinking about doing it, but im not sure if the guys at my work can do it without screwing it up. I'll just have to ask them.
Ask and you shall receive:
Milled them down myself. Reduced the level to 1.5" (removed 1/4"). It did open up some voids which you can see in the picture. Nothing I am concerned about though.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
