Slip Yoke Clunk Symptoms
quaylefarmer
I purchased a 2002 GMC 1500HD 1 week ago.
I noticed a pop / clunk last night when shifting from drive to reverse to drive............
Makes the noies in 2WD only - goes away in 4WD.
Searched all over the web and learned about the slip yoke clunk issue and want to confirm if this is the proper diagnosis for my situation.
All the u-joints seem fine but it does make a distinct "cracking" type of sound when I shake the rear driveshaft (by hand) at the transfer case tailshaft.
Sounds like it is coming from the tailshaft area vs. the u-joint.
Thanks for any help.
Pop it out and grease it, that will keep it quiet for about 2-3 months, before you have to do it again....Or you can get a slip yoke eliminator kit for it.
sorry aiden,drive to reverse is not the slip yoke,slip yoke is at take off ,a chirp/squawk ,you can do what aiden says ,can't hurt,but driveline clunk is nothing new and with this being a new vehicle to you ,drive it or get a tech/shop foreman to take a quick listen.
let us know
Thank you for the responses.
The truck has a 2 piece rear driveshaft.
Do I need to drop the carrier in the middle plus the yoke at the axle to pull out the slip yoke?
cut the clamp that holds the boot at the rear shaft end (mark boot and shaft with paint stick or equiv)then remove the frt peice but there is no movement realy to speak of for that yoke ,but whtever you want to do ya know
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
