Will This Console Fit?
I am thinking about trying to put this console from a 2005 Tahoe into my 08 GMC 2500HD LT2 in place of the jumpseat. I think that the jumpseats from 2000-2009 swap, so I was thinking this should fit. Has anyone tried? Would love to see a pic.
Will not fit directly. You might be able to fabricate some brackets for it though.
