Grease Gun For 04 Gmc
I'm looking for recommendations for a grease gun to grease all the grease spots (wheels, drive shaft, etc.) on my 04 GMC Sierra. Also is there a good all purpose grease to use?
Just a cheap hand pump one for around $30 bucks, I recommend synthetic EP (Extreme pressure) grease.
Edit: the lever style is not a good choice, too difficult to use in tight spots, get a pistol grip. Also make sure it has a rubber hose not solid shaft.
I bought a Lincoln 1134 a while back. best grease gun I have ever had. And I have had several over the years.
http://www.amazon.com/Lincoln-Industrial-1...e/dp/B0002NYDZ8
I second the Lincoln...... Any other brand is a total waste of money...
Jbo
If all he is greasing is his truck he doesn't need to spend a fortune on a grease gun... however, I plan on buying an electric cordless gun soon for the farm :rollin:
Edit: I don't like the pneumatic ones, air hose always gets tangled up and covered in grease
If all he is greasing is his truck he doesn't need to spend a fortune on a grease gun... however, I plan on buying an electric cordless gun soon for the farm :lol:
:D I've never had an issue.
Well some days I go through 2-3 tubes of grease, bad things are bound to happen. Mind you.... hand powered guns are a good work out for the forearms, pump enough grease and you can break someones hand with a hand shake :lol:
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
