Hey Guys,
Im thinking about getting my bed 5'8 bed on my 1500 Line-X'ed just wondering how much you guys have been paying to get this done. I want to compare my quote to some of the others.
Thanks
Hey Guys,
Thanks
I got mine done last September and paid $470 for over-the-rails. It was regularly $490 and I got a whopping $20 discount!! But in my opinion, the Line-X liner is without question the best spray-in/roll-on type bedliner you can buy. WELL WORTH the money!! :(
I got mine done for 500 cash, BUT, he also sprayed my 4 wheeler racks and front bumper I carried with me, so I figure the actual bed was around $400-425.
He said there was a lot of overspray with the racks, and it took almost as much material as the bed.
Believe what you hear here, Line-X is the best liner hands down. Well worth a few dollars extra. I have seen 5 year old liners that looked new done with it.
I also have it in the bed of my Kawasaki Mule, and I toss all kind of things in there, and if I wash it, it looks like it was just sprayed.
C
I had my 08 done. Over the rails, color matched with Xtra. It was almost $750. Worth every single penny. It looks phenomenal, just like factory and the color is amazing. It even has a metallic sparkle look like my dark blue metallic paint.
The price of Line-X tends to be really variable with area.
Most I have seen around here are in the $450-500 range.
really?
my guy said the discounted price was 599. Normally he says charges 750.
That is insane for the standard black Line-X liner! Unless it is the Line-X XTRA product that is strengthened with KEVLAR and you can get it in colors. If it is the XTRA then the price is about right. If that is what he is charging for the Standard stuff, then he is a crook!!!
Have you checked around to see if there are any other shops in your area that spray Line-X? Here is a link to Line-X's webpage for their store locator...
Line-X Store Locator
Good Luck!!! :sigh:
really?
Totally agree. Plain black would have been about $550 I believe.
