does the "Z71"need better sway bars?
i see where ""hellwig&"hotchkis" sells sway bars for the "Z71"trucks but with the bigger bar that comes with the truck.does it need anything out there thats better :bored: i know the rear doesnt have anything but isnt that all the "Z71"needs or front and back? this is a 2001 im talking about
Your right, the Z71's only come with a sway bar on the front.  From what I've heard, it's a hollow bar, and the Hellwig bars are solid.  I'm sure that "stiffens" it up some, which would make it work better.
There is a member here that has installed some aftermarket sway bars.  I can't remember who it is off the top of my head, but if you do a search on sway bars, you may find a thread concerning them.  I do remember he had a link to his website, with some pictures of them.  :D
Yep, I've got the Hellwig kits front and rear.  The front Hellwig bar is not bigger in diameter than stock.  It is just solid.  I've been happy with them.  I would highly recommend them, but it depends on how you use your truck.  I drive mine mainly on road with some towing.  By changing the stock sway, you are sacrificing a little bit of off road ability for much better on road capability.  With the stock bar, you are flexing the bar during cornering, thus the nose dive into corners.  The aftermarket kits deflect less, so you have much less body lean.  This translates to flatter cornering on road.  Off road, the bars would tend to flex the chassis more.  Going over obstacles (rocks, logs, etc) you would tend to limit wheel travel.  If I do offroading, I put disconnectors on the front and rear bars to increase the amount of wheel travel.  I haven't tested this very much yet.
When I had my Jeep Cherokee, I remember there being a disconnectable end-link.  Anyone heard of these?
It had a pin in the middle that you could pull out to defeat the swaybar.
I've seen that type of disconnector before.  I haven't seen them lately.  What I have rigged basically disconnects the front bar and hangs it to the frame and a bungee cord piece that hangs the rear bar to disconnect it.  I'm still working the bugs out.  I saw an article recently about an electronic disconnecting sway bar.  Basically the sway bar is a 2 piece unit with an electronic locking device in the center.  Normally the 2 pieces are locked together.  When offroading, the driver can hit a switch to unlock one or both bars to allow for the max wheel travel.  I don't think it is in production yet.  From what I saw, this was in development for the the Tahoe/Suburban/H2 platforms.  I'll see if i can find that article at work tomorrow.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
