2003 silverado&sierra website
I just thought i would let some people who may not be aware that chevrolet has their website up and running for the 2003 silverados,,,it is pretty detailed however onthe build your own segment you can still only put together a 2002,, however everything else on the site seems okay,, pics, options etc.
 My only question is how long will it take for gm to get 2003 GMC'S SIERRA website up and running since chevrolet now has theirs running???   Does anyone expect the $1000 cashback rebate to extend past sept 3rd??? especially since there aren't many 2003's to choose from,,, i hope so i have ordered a 2003 in marine blue and i won't take arrival in time for the sept 3rd deadline   any rumors on rebates????? for 2003's
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
