01 5.7 Vortec, Missing/hestitating
i have an 01 chevyexpress cargo 2500 5.7. just started missing. confused because everything is new
plugs&wires
cap&rotor
pcv
fuel filter
seafoam treament
cleaned intake&maf
it does need front 02 sensors replaced.. would spraying the old ones with throttle cleaner cause a problem? it seemed to run better the day after i cleaned them..
plugs&wires
cap&rotor
pcv
fuel filter
seafoam treament
cleaned intake&maf
Hi I have a similar van A 2001 Savana 3500 with 5.7 vortex engine. how is your van holding up? How many miles:?
How do i test/check to see if its a bad injector?
i thought about replacingthe coil pack with a msd replacement
just replaced the fuel pump.. still have to hold the key on for the pump to cycle so it will start.. and the miss seems less but its still there at different times. not so much under a load. more at low rpm,s
is there a fuel pressure regulator on this model somewhere at the engine that could be the problem,
  • 1 month later...
fuel pressure is located in the intake manifold along with the injectors. do a compression check, all cylinders should be within 10% of each other. should be 130psi-150psi. if lower,like 90psi there is internal problems, valves or rings.
since my last post i changed the fuel pump, runs slighty better, but still have to hold the key for 5 secs before trying to start, and the miss isnt real bad its just there in an out, seems at lower rpms
Used to have a 1998 5.7; one of the injectors stuck and it missed / hesitated real bad. My understanding is that there is a valve in each injector that sticks, an engine clean can solved the issue.
But it threw a code right away, are you seeing a code?
Had the same problem at low RPM's and sometimes when taking off, just a slight miss or hesitation. Threw a code saying it was the MAF sensor so I cleaned it out. It helped a little bit but it would still intermittently miss. Decided to just change out the MAF for $130 from Advance Auto. Fixed the problem and now she runs great.
i cleaned the maf real well,and see an improvment. i cant imagine thats all it was.
im gonna replace the stock coil with an msd or something..when its moist out it seemed slightly worse
