04 Sierra P0300 Problem
I to have this same issue with the missing and flashing cel. I've replaced plugs, wires, fuel pump, moved coils around and keep getting p0300 and p0171. I have pinging at high rpms and a serious shutter on cold starts. I've read that a crank relearn helps. But I was also wondering if just changing the crank position sensor will do the job? I'm sick of shitty mileage and I do alot of towing and travel so any help would help.
Have you checked fro vacuum leaks? Especially intake gaskets
can you replace the crank sensor which is located above the starter motor on the block on most 6L. ?
then crank sensor relearn?
Too Many Questions because I can do it my self as well if the tech replies to the other posts.
scooby
Yes, you can replace the crank position sensor. Be warned, it's a pain in the ass. I finally cleared up this ongoing issue with my truck by replacing a dead/dieing coil pack.
  • 1 year later...
How did you figure out what coil pack it was??
