Alternator / Gauge: Voltage
Blue2500CC
My '10 1500 5.3 is doing something weird IMO. When you first start the truck, and for a short time, the needle indicating the voltage, according to the dash gauge, is actually almost completely past the 4 of the 14. After a short while, the voltage output according to the dash gauge actually drops below the 1 of the 14. It is almost like after the alternator "warms up" the output is dropping.
I haven't called the dealer YET, figured that will be later this week when I have a little time.
Any thoughts??? Or am I just crazy and this is "normal" for the newer trucks???? My 2k never had a drop like this, and alwasy stayed above 14 volts according to the gauge.
RPM's do not seem to matter either.
Thank you!
Chris
Some customers may comment that the volt gauge fluctuates between 12 and 14 volts on their 2005-08 full size pickup or utility vehicle. Starting with the 2005 model year, these vehicles are equipped with a Regulated Voltage Control (RVC) system. RVC reduces the targeted output voltage to 12.6-13.1 volts when in Fuel Economy Mode to improve fuel economy.
The generator may exit Fuel Economy Mode if additional voltage is required. This causes the voltmeter to fluctuate between 12 and 14 volts (fig. 16), as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts.
This fluctuation with the RVC system is normal system operation. No repairs should be attempted. Refer to the owner manual Section 3 (Instrument Panel) Voltmeter Gage for more information.
TIP: Refer to PIT4426 for concerns with keeping a camper or trailer battery properly charged.
13.8 Volts is "normal". Keep in mind that the gauges only "approximate" the actual output of the alternator. Most are somewhat accurate but not right on the money.
Good to know. Can this be tuned out of the PCM?
Leonard,
Thank you! As just asked, is this something than can/should be reprogrammed?????? Or only if there is an issue maintaining a charge? I wondered if this was something that was designed.
Jim,
I realized there are tolerances, but thought this had to be the alternator due to the amount of change. But you never know till asking or "digging in" and checking.
TY!
Chris
If your not having any trouble, leave it alone. It also is suppose to help increace the life of the battery when it goes into fuel saving mode.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
