Transfer Case Help
okay so my np261 has the infamous pub rub problem and its gonna cost me $600 to repair what i have(alum. chain drive transfer case)....Okay so heres where it gets interesting...i want to swap in a ford NP205(cast iron Gear-Gear transfer case).....but cant find any adapters.........wonder if any one on here has done this swap or knows where i can get the adapters or info on the swap........thanks in advance.......
Well first what you have is magnesium, not aluminum.
I guess my first question here is why? Unless you have a 205 for free somewhere it's going to be a lot of work.
First you'll need a 29T input gear installed in the Ford t/c (assuming you have a 4L80).
I think the center distance is the same but odds are the drop angle is wrong. If it's too low the from propshaft won't clear the trans crossmember.
You'll need a custom prop front and rear since the NV261 is slip spline front and back.
You won't be able to shift on the fly since the NP205 doesn't have a synchro. If you want to shift on the fly you'll have to make a plug spacer to keep the front axle in all the time. Otherwise you'll have to rig a switch to engage the front axle (while stopped) and leave the front axle engaged in case you need 4wd on the fly (as you would do with manual lockout hubs).
The NP205 doesn't have a tone wheel. You'll need to use a custom tone wheel setup either at the front or back of the rear propshaft like the streetrodders use that is calibrated to imitate the one in the NP261. If the tone wheel for the VSS is not right nothing [auto trans, abs, speedo, engine controls] will work properly.
The Np205 is not as low in 4LP having a 1.96:1 low where your NV261 is 2.72:1. This is also going to mess up your shift points and make the PCM have a fit in 4L0 since RPM, gear position, and speed are not going to jive.
The NP205 is a lot heavier as well.
Those are the things that pop into mind. I would not recommend that swap.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
