Any Pics Of A Reg Cab Leveled With Stock Rims And Tires
I think I want to raise the front end of my 2wd regular cab W/T but dont intend to buy larger wheels and tires. Will this look crappy and does anyone have a pic? Thanks
I leveled mine with the Rough Country 2" kit and still have the factory wheels and tires until I can afford the 33's and wheels. I think it looks better than it did stock, not goofy or anything. This is the only picture I have right now, sorry if it sucks.
No, its a great pic, Thanks! I went out and measured the distance between the top of my tire and the curve of the wheel well opening and found that I have about 6.5 gap up front and about a 10.5 in the back so im confused now as to what I need to do to level it. Thats a 4' difference so I dont think a 2.5 inch level kit is going to get it done?!?!
Try to measure from the ground to the fender on the centerline of the wheel. Make sure you're on as level of ground as you can find. Shouldn't be 4", that seems a bit high. If it is still a 4" difference, you could do a 2" level and pull out the rear blocks.
