Bumper Adjustment Mod
I've never been happy with the gap GM left between the grile and upper bumper pad. my gap was about 7/8" to 1". I dissasembled the front end to see what I could do to close this up. A second set of hands would have been nice, but was not necessary
Before:
Alright, here goes. The Bumper Adjustment Mod
1) Start by taking your headlights and turn signal lights out. If you can't get these out, abandon all hope and turn in your man-card.
2) Remove the plastic radiator cover that bridges the gap between the grille and core support. there are 7 little push pin connectors.
3) Remove the grille by pulling straight out on the 6 retaining clips
4) If you have these scoops behind your tow hooks, you might want to remove them. There are two 10mm bolts, one on each side of the frame. The scoops are a one piece plastic with a hinge on the top outside edge of the frame, so the top has to slide over the frame then down and out of the way. This is the drivers side
5) If you have fog lights, it is just easier to get them out of the way to give you a little more space. Two 10mm bolts hold them in.
6) Now with everything out of the way, you have clear access to the 6 bolts that hold the bumper to the frame brackets. A 19/32" socket worked for me.
A. There is one on each corner bracket
passenger side:
drivers side:
B. There is one on the top of each frame rail
Passengers side:
Drivers side:
C. There is one on the inside and toward the bottom of each frame rail
Passenger side:
Drivers side:
Remove all six and set the entire bumper aside. You'll want a blanket or something soft to lay it on….I used the lawn.
7) The BUMPER BRACKET that originally sat below the frame needs to be cut to allow the bumper to move up. Do not cut your frame! I don't have any before pictures, but if you crawl under and look at it before you remove the bumper, it is kind of obvious what needs to be cut. This is a pic of how much needed to be cut off the BOTTOM OF THE BUMPER BRACKET to get it to be able to move up.
If you're afraid to cut this bracket, put everything back together, pick up your purse, go back inside and watch Oprah. Since this bracket goes underneath the frame, this is a necessary step to move the bumper up. Again, this is the bumper bracket....NOT THE FRAME BRACKET, DON'T CUT THE FRAME!
8) Take the retainer clip/nut off of the bottom bumper bracket and place it on the frame lower bracket. Again, I don't have any before pictures, but here is the clip/nut I'm talking about already moved from the bumper bracket to the frame bracket.
9) Now for the washers, I used these ½ zinc coated flat washers.
Five or six on the top of the frame, three or four on the bottom frame bracket. The reason you don't need as many washers down on the bottom bracket is because you're going to switch the way the plates originally stacked. Before, it was the bumper bracket under the frame bracket. Now, it's the bumper bracket on top of the frame bracket. You're going to have to do the adjusting by trial and error here because every truck is different and your washers might be a different thickness than the ones I used.
10) Waddle your way back to the truck with the bumper. Without spilling any washers, carefully set the bumper back down on the washers.
11) Start the threads on the top and bottom bracket bolts to secure them all. Now tighten these down good and snug.
12) Put your grille back on the truck to see how the clearance is. I left about 1/8" gap between the upper pad and bottom of the grille. If it's too tight, readjust with less washers. When you're satisfied with the gap, double check the fitment right to left, adjust accordingly and tighten back down.
13) Put your turn signal lights and headlights back in.
14) At this point your bumper should be saggy at the fender openings. that's because we haven't addressed the corner brackets yet. If you have help, now would be a good time for it. Push the bumper up toward the fender until your desired gap is achieved. Use a vise-grip to clamp the corner brackets together, double check that you have the gap you desire. Do the same to the other corner.
15) When both drivers side and passenger side corner brackets are clamped together, step back and take a look at the fitment of both sides from MANY angles. When you're completely happy with all the gaps, crawl back under and drill (with a 7/16" bit) through the existing hole in the corner FRAME BRACKET into the bumper corner bracket. I reused the stock bolt with new washers and nuts. Tighten these down.
16) Release the vise-grips and double check all hardware and make sure it's secure and tightened down
17) Reassemble the fog-lights, plastic scoops behind the tow-hooks, and plastic radiator cover. Shut the hood.
18) That's it! Step back and enjoy your new tight lines!!
interesting, i've actually been sniffing around for how to take my bumper off as it is slightly sagging on the passenger side...needless to say i'd rather not take the grill out lol...
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
