Installing Trans Temp Gauge?
i am thinking about putting a trans guage into my 07 classic silverado 1/2ton .i have a big road trip coming up hauling a hot rod through the rockie mountains and i think it would be a good idea.
i am trying to figure out how i would go about doing this, if it would be better to get a shop to do it or if its fairly straight forward. also what i would need to do an install like that..
Here is a search for other threads that discuss this.
Trans Temp gauge
One way is to swap out your current instrument cluster with one that has the trans gauge on it (your vehicle is already wired for it). Or you can purchase a Scan Gauge and hook it up. With the Scan Gauge you can monitor many other vehicle sensor output.
Trans Temp gauge
would you happen to know what the other thread is called? it says they only ship in the states, do you know of any place to get the scan gauge in canada?
Trans Temp gauge
Click on the link in my post for a search. There are many posts to look at
IMO, installing a temp gauge is only half the job..... ok so now you can monitor it, but you didnt do anything to help keep temps down.
on my 2005 I installed a mag hytec trans pan and put synthetic fluid in. This increased fluid capacity and added cooling.
The trans pan has a port in the side of it for a temp sensor. So i also bought a temp gauge and a dual pod pillar (i like the dual because it covered the whole pillar and looked "factory"... i put a cheap a/f gauge in as a filler for the 2nd spot)
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
