another slight prob--inside for problems
Zane
Hi guys and gals,
We accidently FUBAR's last night and deleted the wrong file, making the forum down this morning, and i think erasing all the settings we had.  Like the smilies are back to the default, etc, can post your own member title, etc..
Both SiiLT and I are on the road at the moment, but i will be back Saturday night, and will address these problems Sunday morning.
thanks!
