Got New Parts On
so i installed my new amp, shocks and struts, ebc rotors and hawk pads. truck stops great. it rides really well until it hits a big bump then it's way too hard in the rear. would probably be great towing something. but on really rough roads at highway speeds it jars you something fierce
the sub amp will go on the left of that amp
I have to wonder if the ride quality issue is due to the particular shocks you bought, or if the problem is a result of the accident damage....
Otherwise, lookin' good!
What brand of shocks did you buy?
procomp es9000 shocks.
  • Twin tube nitrogen gas stabilized
  • 10 stage velocity sensitive valving
  • Expanded twin tube design increase fluid capacity up to 50%
  • 1 3/8 inch nylon banded piston
  • 5/8 inch chrome hardened piston rod
  • Optional shock boots sold separately
i think it may just be the shocks and the 10 way valving.
it was riding fine with the factory shocks, so i don't think it's because of frame damage
Those shocks are pretty stiff. They will loosen up a little with a few miles but remain somewhat stiff.
Nice, I'm thinking about getting the RS9000XL Rancho's they have 9 clicks of adjustment, and are supposed to be pretty good, and hold up good. They have a 100 off them till august, so I got a while to think about it.
How are your brakes?
brakes are awesome, just a bit of noise, you can barely hear it except when going by retaining walls. i will never run anything any differant. they are very progressive and will stop the truck quickly when needed
how did you mount your amp? Did you just screw right in to the metal there? :jester:
Nick :troll:
yep self tapping screw. i put it in then take it back out and put silicone around the hole and on the screw and remount it
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
