Exhaust
mark1223
I was wondering if gm makes a true duel exhaust system for the 2007 silverado classic? If not, where can I cut it, so it will not void my emissions warrenty? Thank
the CAT has to stay for sure, that pretty much is the emission control lol
I plan on keeping the cat for the rumble, but I didn't know if I had to go collector back, or if I could cut it off behind the cats? Thanks. Some one had said, he thought gm made a true duel, but he thought it was around a grand, but all I have seen is a one into two. Thanks
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
