Will It Void My Warranty
good day all, just bought a 2010 Sierra SLE, was told to change air filter to a K&N for better gas mileage? but will it void my warranty in any way? and is it worth the money?
thx all for any help and information.
Will it void warranty? No, unless the problem is maf related. Is it worth the money in gas savings and power? IMO, no.
If I had to do it over again, I don't think I'd put a cai on my pickup again. It does, however, make it sound better and look better under the hood.
I would agree with the above post. It will only mess with your warranty if you take it in for a problem and they can directly tie the problem to the K&N air filter. Once such example is the mass air flow sensor. Over oiled or heavily oiled filters can cause an issue with the sensor. My .02 is not to waste your money on just a filter as it will be highly unlikely you will see any gains from it. You might see better gains if you replaced the whole air intake, but that is just an assumption too.
it will not help your gas milage. I have one in my Tahoe and Truck neither seen any milage change.
I looked around the K&N web site and I don't see where they say it will increase your mileage.
K&N makes no general fuel economy claims, however we encourage you to try our air filter for yourself.
Anecdotal evidence based solely on the experiences of individual consumers is insufficient to support claims related to horsepower, torque, fuel economy. People’s opinions are not facts that can be substantiated. People tend to exaggerate as a means to justify their reasons for buying a particular product.
when i took my truck in about a month ago, the dealer asked me about my cai and filter. i told them it was a k&n and they told me that it can void my warranty because of the oil. of course they do have to prove it, but there is a bulletin out about it. still havent taken mine out tho.....
Personally if you have the warranty just don't touch anything until the warranty is up. Best way to go because even if what you added/changed didn't cause any future problems the dealer could come up with some BS example to "prove" it was your addition that is at fault, void your warranty and then get out of having to do free expensive repairs.
Maybe I'm jaded, but I wouldn't put it past dealers to pull something like that. I don't know how the finances work but if it's anything like the company I work for, we sell our warranty hoping the customer never uses it, and if they do we don't really make any money.
it will not by just having it, if you have a failure..then the dealer has the burden of proof by having to find evidence that an aftermarket part caused the problem...CAI and snake filters like K&N are a waste of money...the stock box and filter can support almost anything that motor can push out, cheapest way to get better mileage is to drive like an old lady.....
this site is awesome, I thank you all for your coments!!! i guess my gas mileage will stay the same because I can't see me buying a K&N air filter and there is no way I'm driving like an old lady!!!
enjoy your summer!
Robert.
How do you figure? If I have to buy an air filter every 2 yrs lets say thats about $25 appx. Well I paid $50 for a re-usable K&N so basically it will pay for itself after 3-4 yrs?
GOOD POINT
you can easily take the stock filter out and tap it off for another use unless your driving in some extreme enviroments, its works great...have done it for years on tractors with paper filters..
The oil air filter will not void any warranty READ THIS
Info - Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled Aftermarket, Reusable Air Filter #04-07-30-013A - (Jan 25, 2005)
2005 and Prior GM Cars and Light Duty Trucks
2005 and Prior Saturn Models
2003-2005 HUMMER H2
This bulletin is being revised to add additional model years and to clarify warranty coverage. Please discard Corporate Bulletin Number 04-07-30-013 (Section 07 -- Transmission/Transaxle).
DO THIS:
First, Inspect the vehicle for a reusable aftermarket excessively over- oiled air filter.
DON'T DO THIS:
DO NOT repair MAF sensors under warranty if concerns result from the use of an excessively/over-oiled aftermarket, reusable air filter.
The use of an excessively/over-oiled aftermarket, reusable air filter may result in:
• Service Engine Soon (SES) Light On
• Transmission shift concerns, slipping and damaged clutch(es) or band(s)
• Engine driveability concerns, poor acceleration from a stop, limited engine RPM range
The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.
When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively/over-oiled air filter. The MAF, GPS reading should be compared to a like vehicle with an OEM air box and filter under the same driving conditions to verify the concern.
The use of an aftermarket reusable air filter DOES NOT void the vehicle's warranty.
If an aftermarket reusable air filter is used, technicians should inspect the MAF sensor element and the air induction hose for contamination of oil prior to making warranty repairs.
Transmission or engine driveability concerns (related to the MAF sensor being contaminated with oil) that are the result of the use of an aftermarket reusable, excessively/over-oiled air filter are not considered to to be warrantable repair items
People who make this argument never mention the cost of the cleaning kit which is an another expense plus the time it takes to wash, dry and re-oil. So I don't really see that you are saving much $$ if you are spending $15-25 for cleaning and oiling supplies and how many times in the life of the filter? I bought an AMSOIL EAA123 for my GMC. I can clean that with just air, does not use any oil and is good for 100,000 miles and only cost me $48. The K&N cost about the same and I have to buy a clean and recharge kit for ?? and how many would I need in 100,000 miles? More than 1 likely.. K&N does not save you money IMO if you factor in the supplies and the time wasted doing the work.
cleaning kit for K&N is only around $10 and lasts a good 4-5 uses.
you're only supposed to clean the K&N every 50k miles (more often for offroad/dusty use).
So for normal driving.. it costs you about $10 for 200,000 miles for the cleaning kit (although i clean mine yearly; but if i used an oem style paper filter i'd be changing it every 10k miles or so anyways since im crazy with my maintenance).
I see your bold and add some bold myself. So no the use doesnt void the warranty but if the MAF sensor fails because of the use of a oiled filter is is not considered a warratable repair..........you must always read all of the fine print.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
