Factory Trans. Temp Gauge
Not sure where to post this but. Has anyone ever added a factory trans temp gauge in the dash . I have a 99 gmc 1500 would like to add the factory gauge....
Yep...buy a new cluster. This is what I did:
That's an Escalade cluster right? I believe so.
The problem is the OP has a 1999. The electronics are unique to the 99. If you use a 2000 through 2002 cluster, they will work with the exception the air bag light will stay on all the time.
Some of the cluster guys, suppliers out there can provide a cluster with a temp gage for the 99 that will work. You just can't pull one from another vehicle and install it with out the airbag light problem.
