Hid Problems...
Whenever the HID lights are on I lose some radio stations, once you turn the lights off the radio stations come back. Anyone else experience this problem or have any ideas for a solution?
Thanks!
My buddy did in his SS Silverado. From what I hear it is somewhat common. Somethin to do with frequency disturbance. I may be way off but I thought this kind of thing can happen with certain spark plug wires too.
That is the most logical explaination as any Frequency band stronger than radio signal will kill the radio signal. However, this should not happen on FM band as FM band doesn't not use Amplitude Modulation which is the most common result of Spark plug and or other stray engine generated frequencies. If FM radio stations are fading then there is an electrical interference to the circuit board of the radio itself. This means most likely that there is varying Votage to the radio unit...
Yep! I had this problem in my Colorado. It's the ballast of the HID's, when they lights are turned on it, you can get static on radio stations as well as all CB channels.
You could try relocating the Ballasts. I have no issues with radio stations with mine and I have HID low beams as well as fogs...
FYI, my low beam ballasts are mounted to the inside of the radiator support and the ones for the fogs are mounted to the supports for the bumper above the air dam.
i have them for my fogs and my ballasts are located the same as yours and my radio barely works. but i never use it XM.. the only reason i noticed it is because when i put them on in my garage i tried them and it killed the radio in the garage when i turned them on
Dont know if it makes any difference at all but i got my HID's from EBAY from Lighting623. I would think that a ballast is a ballast..
Normally a ballast is a ballast. Is it mounted directly to the metal? What we used to do in stereo installs was to run a ground strap to the hood. Because a ballast essentially a transformer, the harmonics produced by the transformer will interupt certain frequencies maybe all. Your HID ballasts hum the same way a large transformer does you just can't hear it. But your radio can! Are you using the truck body as your negative terminal and your ground? This could be causing a problem. Try using the negative terminal for negative (even though it connects to the frame) and connect your ground to the body. I don't have HID's so take this advice for what it is worth.
Oh, one other thing you may try that is prolly different between our setups. I am NOT powering the HID Ballast off of the feed from the headlight. I have independent relays directly off of the battery that are closed by the voltage from the headlight circuit.
In my colorado, I had wrapped my ballasts in aluminium tape to reduce the noise which is did slightly.
On my silverado I no longer have that problem. The HID setup, I took the time to do a nice install. All ballasts are mounted to the frame of the truck for both my low beams and fog lights. I suggest relocating your ballasts, or worst case get a new setup.
    JohnRoy
    JohnRoy
  • Who's Online   6 Members, 0 Anonymous, 647 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
