1989 Sierra Rear Suspension Question
My 1989 GMC K1500 needs a couple of rear suspension parts to pass state inspection. These aren’t typical wear parts… the truck was used to haul a boat by the previous owner (15 years ago) and it’s really rusty underneath. I’m surprised that the rear axle hasn’t fallen off yet. The parts that I need are the following:
Spring Anchor Plates – these are the plates that mount under the axle tubes where the U-bolt washers and nuts are. Mine are pretty much non-existent. After talking to the local dealer’s parts department, there are left and right versions of these and they can still be ordered. Interestingly enough, the LMC Truck catalog only shows the right side for a ½ ton pickup.
Spacers – these are mounted above the leaf springs. These are formed to locate the U-bolts at the proper spacing. There are 3 different part numbers listed for these, apparently stamped with a “V1, V2 and a V3”. I have no idea of what mine had on it, because they’ve basically dissolved. Does anybody know anything about what the “V” numbers mean? The only thing I can think of is for different width leaf springs on ½ ton, ¾ ton and 1 ton trucks. Any help here would be appreciated.
U-bolts - according to the dealer, these come in M14x2-240 and M16x2-295. The M14 and M16 have to be the thread size and I’m assuming that the last number is the length. I can measure the length from what’s left of the original U-bolts, but the thread size is going to be tough. What should the ½ ton K1500 have come with?
This might all be clear if somebody has access to the parts manual, or better yet, if somebody has a link to an online version, please send it to me.
Thanks,
Mark
Thanks,
Mark
Why not go to a junk yard and find a rear axle and other components for your truck? It would save you a lot of headache down the road
I did call around to a couple of local yards and nobody had one with 3.42 gears. I think the cheapest fix is to just replace the U-bolts, spring anchor plates and spacers. I can probably get a measurement off of the U-bolts, but I'm not sure which of the 3 spacers I need. The LMC truck catalog only lists one spacer for 1/2 ton, and just one style of U-bolt, but the girl at their call center knew nothing about them.
Does anybody have any suggestions on other vendors?
I'd try Rockauto, they usually match parts like that based on year, 2wd or 4x4, engine size etc.
And seriously.... Por-15 that rear axle. I thought my '97 looked bad before I POR'ed it, but that poor thing needs it worse than mine.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
