Sound Dampening Material
MarkD
I bought some "Brown Bread" and intend to cover as much of the interior as possible (starting with the doors and rear wall).
Does anyone know how much it would take to do the entire interior?  BTW, I have a 4-door ext. cab.
( I bought 70 sq. ft.)
I am not interested in doing the roof right now.  I am sure that would help a lot, but I am intimidated about messing up the headliner.
Measure and get your own estimate.  Measure the width and length of a door, multiply times two and divide by 144 (12"*12").  That will give you about how much it will take to cover the front doors.  If you want to do the inside of the doors also, add like 2 sq ft per door.  Do the same thing with the rear wall and the floor (just don't multiply by 2).  If you want to do two layers, just multiply your final number by 2.
I have a single cab truck, and 70 sq ft wouldn't be enough to do the entire inside for me, but I like two layers everywhere.
Length*Width/144
Mark I did the whole cab on my 02 ext cab.  Took me two rolls of Raamat 60.  Each roll is 62.5 sqft so 125 sq ft.  I did the outer door skin and inner door skins, floor and back wall.  Took longer to put the sound deadening in than to install the system.
Have you guys been satisfied with the return on effort?
If I take the time to double layer the entire cab, I would expect to have a Sound Vault.
Mark,
I cant wait to hear your results.
BTW, i thought BB had a better material for the floors and firewall that was a thicker different kind of material??
You might want to check that out if its not too much more expensive.
Hmm i found it, but yeah, its more expensive to add this stuff.  I bet it would be killer tho :cheers:
Vcomp
Vcomp is a noise barrier composite consisting of a dense vinyl based polymer barrier with a 1/4" thick foam decoupler. It has a total thickness of 1/2", weighs just over 1.0lb/sq. ft.
Vcomp is meant to be installed on floors, doors and firewalls to reduce road and engine noise. Using a damping material in conjunction with Vcomp will offer the optimum performance.
13.5 sq. ft.= $64.99
27 sq. ft. = ON SALE! Regular $114.99 USD  $99.99
And better still :cheers::
LComp
Lcomp is a noise barrier composite consisting of a 1/4" absorber foam with a black urethane film facing, a lead barrier and a 1/4" thick foam decoupler. It has a total thickness of 1/2", weighs just over 1lb/sq. ft. and it is highly moldable to form to the contours of your vehicle.
Lcomp offers the best performance amongst composite materials and is meant to be installed on floors, doors and firewalls to reduce road and engine noise. Using a damping material in conjunction with Lcomp will offer the optimum performance.
Each sheet measures 48" x 24" for a total of 8 sq. ft. per sheet.
B-Quiet Lcomp
8 sq. ft. = $69.99
16 sq. ft. = $119.99
24 sq. ft. = $149.99
Hey, I did my whole cab, doors and back wall in my Ext-cab. I bought the sheets from www.partsexpress.com (10"x10"sheets). I put two layers in because I wasn't satisfied with just one. For my ext-cab, I used about 150-175 sheets of the 10"x10". You can click on my personal site and you can see the small write up I did.
Definitely a full weekend project. Heat the sheets up (put them in the sun) as they are a lot easier to use when hot. They form better.
Major improvement. My next step is to replace the carpet padding with thicker padding. Still getting more noise than I want, so it's the next step.
Fun taking everything out of the truck too. Crank it up when everything is out, you'll be amazed how loud it is.
Heck yeah!  I had the carpet/insulation out of my '91 on time for about a week because it got pretty wet.  I drove it around for a week with nothing but the seat and floor mats in it.  It was very loud, and hot too.  :nono:
  • 4 weeks later...
How much improvement can you expect from soundproofing?  Would you say it cuts the niose in half or better?  I've been wanting to do this for a while and want to make sure it is worth the money.  How much should you expect to spend for the entire inside of ext cab?
I'll repost what I posted earlier on this post.
Length*Width/144
I've used about 150 sq ft in my truck and it has made a big difference.  It cut out a lot of road noise, and made my stereo sound better.  Definitely a well worth it investment IMO.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
