Bose Sub Woofer Replacement
You will need something like a clean sweep or rockford fosgate 3sixty to clean up the signal coming from the stock stereo. The stock stereo has it own eq. One of these signal processers will flaten that eq of the stock radio which will allow the amp to do its on thing. It will act more like an aftermarket radio once you add one of the processers.
THAT'S what it was called! I was trying to think of it the other day. JL Audio Cleansweep. They were like $400-$500 at the time though...So I gave up.
Ahsmo...You do good work. I can't work with glass to save my life. :P
You have to use their volume control on those silly things. So basically those things are a waste of money imo. This works better: JBL MS-8
Thanks wingnut.
EDIT:
I was wrong about the volume control. The clean sweep will allow you to use the factory volume control. But the MS-8 would be sweet.
  • Replies 59
Yeah, I've received multiple responses that there is indeed a line level output from the factory HU, and that this line level output goes into the Bose amp's input. So I'm going to go on a search for that pretty soon when I get back from a business trip.
As far as fitting the 8W7s: The issue is of course the size of the magnets. They are quite huge for 8s. I've seen some box designs that involve downward firing of the subs... but I don't want to go that route. I want them to be visible on the front of the box under the seat. I haven't done all the measurements yet so I can't say it's even possible, and I haven't seen anything online about it.
But...it seems that if I construct the box with a slightly angled face such that the magnets angle downwards I might be able to make them fit. If necessary I could raise the seat an inch with spacers.
I dunno, once I get in there and start measuring I might just say to hell with the 8W7s and go with some REs :sigh:
Once you take the center console out, the wiring harness is easy to get to. I really don't think the Bose version I have does any sound modulation that would require a JL clean sweep. So if you have the same, that line level out will sound good.
Check out what this guy did. It is pretty much exactly what you are talking about. I think the w7s might be a little bit deeper but this guy's digital design subs look huge.
http://gmfullsize.com/forum/showthread.php?t=186466
I put the truck back together this afternoon. Before I did that I moved my ground to a stud on the floor of the cab that some part of the tire changing system attaches to. I used some 80 grit to get the paint off the floor around the stud before I use a nut to secure the ground terminal. You can see a stud I tried to use but I couldn't find a nut to secure the ground terminal so I used the stud under this black thing.
I also did some trouble shooting on a problem I thought had to do with signal transfer from the Bose amp to the high level inputs of my amp. Turns out the ground on the high level inputs does not need to be hooked up to ground. If you do hook it up to ground you get a nice alternator hum.
I also put my remote sub woofer volume control knob in the center console.
I am going to hold off on saying how it sounds for a few days until I get used to listening to it. Thus far I have just been listening for distortion for just a few minutes at a time.
I have a sub hooked up to my factory bose right now with no problems. I found the low level imput before the bose amp that I tapped off of since my amp has low level inputs. I just have my exsisting bose sub disconnected. I am also waiting on the outcome of this project because I have been debating on doing the same exact thing esp since I am not useing the bose sub any how. thanks for the updates let us know how you like it.
Larry
Larry
Which low level inputs did you tap? The rears? Or is there a separate one for the subwoofer?
I will keep ya'll updated.
Its been a while. I'll have to look at the wireing diagram I have and see which ones I tapped. I just used a speaker wire that had rca connections on the other side for my amp. I picked them up at radio shack for about $15. Been working fine for about 6 months with no amplified door chimes or turn signals. I'm about to change out my front speakers and add another amp by passing the bose altogether. that is as soon as I make up my mine which components I'm going to go with LOL
I drove over to the grocery store with my wife in the truck today and here is what I thought:
The bass certainly is louder. The 8 inch sub will play down pretty low but not at terrifically high levels at lower frequencies(its an 8 go figure). I forgot :cheers: to put in poly fill before I put the woofer into the box. Poly fill would have slowed down the back wave and made the woofer "think" it was in a larger box than it really was. By the time I realized my mistake I was halfway through installing the console. It is punchy and sounds good with rock and country. When I turn the volume up the bass does not seem to draw down relative to the other speakers. I was listening specifically for this the whole time. I played different types of music to try to detect it. I am overall pleased with how much bass I have now. The volume knob in the center console allows me to turn the sub down when I want it to really blend well with the rest of the speakers or turn it up when I have a song on that I really want some more bass out of.
My reference system was in my old car that had several different woofer setups. My loudest setup hit 137db on the dash with a term lab mic. My best sounding setup was with two Boston Acoustics 10s in a sealed box powered by Phoenix Gold Amps.
Things I would have done differently:
-Not glassed in the speaker rings. The first board I cut was fine.
-Put poly fill in the damn box
-Figure out a better source for a switched 12+ source. The white wire on the Bose amplifier harness works fine but does give a turn on pop. The solution is buy one of these PAC-Universal Trigger Output Module or come up with a circuit that will delay the turn on and turn off. I may correct this by going with the latter of the two for fun. The pop is only present when putting the keys in and turning on the radio then starting the truck. If you just start the truck there is no pop.
-glassed the inside of the box. I am worried the ABS plastic will crack one day but when that happens I'll build a bigger box to fit in that space.
LivNLo94's original design was like so:
I am thinking of modifying it like so:
I am going to get all of the proper dimensions and do the real calculations but I am thinking this is possible, so it's at least worth pursuing.
Did you check and make sure that the w7 won't fit with his box specs? I just ran some numbers and it looks like there might be enough. The angle design will certainly work.
Actually no I had just assumed it wouldn't fit. But looking at it, you're right, there's a chance that it would. I have the drawn-to-scale schematic of the 8W7 from JL's website so I'll use that to make the determination. Good thinking.
The bass certainly is louder. The 8 inch sub will play down pretty low but not at terrifically high levels at lower frequencies(its an 8 go figure). I forgot :cool: to put in poly fill before I put the woofer into the box. Poly fill would have slowed down the back wave and made the woofer "think" it was in a larger box than it really was. By the time I realized my mistake I was halfway through installing the console. It is punchy and sounds good with rock and country. When I turn the volume up the bass does not seem to draw down relative to the other speakers. I was listening specifically for this the whole time. I played different types of music to try to detect it. I am overall pleased with how much bass I have now. The volume knob in the center console allows me to turn the sub down when I want it to really blend well with the rest of the speakers or turn it up when I have a song on that I really want some more bass out of.
Very good info. Thanks for posting this thread and keeping us up to date :lol:
In case anyone is referencing this thread for their amp install...
The clearance between the seat and the back wall is a major consideration. I mounted my amp on a .5" piece of ply wood and I got lucky that it fit. If I were doing it again today, I would use something much much thinner to glue to the back wall. DO NOT mount your amp to the back wall with self tapping screws. That is just plain lazy and may cause a huge ground loop between the amplifier chassis and the truck.
I did exactly that on my '02 (self-tapping screws) ex-cab. Never had a problem. That system was great. I wound up redoing the whole thing and putting the amps on a board...But I didn't have a problem while they were screwed directly into the wall.
Here was the first try, before I cleaned up the wiring:
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
