Not New but....
Fast4.8 Part 2
Guys, I have been e-mailing the webmaster for a week now with no response. Since the re-do of the site, I can't log in under my original name "Fast4.8" because now my password is to short. I also could not even access the forum until I created a new account. So here I am and I would like to get someone to fix this for me. I had a 4 letter password since I became a member in 2001 and now, I guess it has been changed to a min of 5 letters. Could someone reset my original account password and email it to me so I can log in under my original "Fast4.8" ?
Thanks,
Greg
Sorry man! The emails and everything has gotten messd up.
I'll email you...
