Drive Selector Is Getting Very Dim
VERY common problem with the clusters on the GMT-800s, either the gear indicator and/or odometer will go kablooey. Only solution is to have it rebuilt/repaired, or replaced. Nothing you can fix yourself in most cases.
Any idea of how difficult it is to remove/replace?...cost of new part(s)?...what dealer would charge? Thanks much! Mc
Ebay
2004 2500 hd gas. the prndl is getting so dim it is hard to see.any ideas?
There was a recall out to replace instrument cluster free of charge for those who are under 75,000 miles I think. If over that, they just charge you for the labor last I heard from a GM dealer who replaced my instrument cluster last Summer.
Yeah I think that may have ended. When they did mine in 07 they told me the recall was nearly at the end of it's time limit.
Certainly worth checking into.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
