Driveline Vibrations?
any other 800s experience very quick pulses of vibration in the driveline in reverse or in 1st from a dead stop? its only there for a second or two and then smooth...its more noticeable when its cold also..:rant:
i have noticed it before, it is weird.
I've had same complaint. Dealer looked at U-Joints, said a little dry. Regreased with NO change. I have since changed for new joints, Vibration or "shudder" is still there. Dealer also mentioned possible exhaust resonance causing it. I'd like to hear from others if this cause can be found. Noticed more when gentle on throttle, like parking lot driving.
its not like heart shaped bed in cheap motel that takes quarters vibrations...its just a quick pulse, maybe it is the exhaust i have heard that a few times before also...glad i'm not alone lol
I'd check and lube the slip joint splines in the drive line
I tried that while replacing both u-joints. Splines looked clean. Added grease, and wire brushed rust from outside diameter at the seal location. Still have the "shudder or slight vibration" Maybe an exhaust resonance. I remember reading about an exhaust resonance counterweight being added to some trucks at one time.
  • 6 months later...
the experts around here told him about some sort of issue with the exhaust rattling...solution is some sort of weights...i just live with it
