Aftermarket Brake Controller Into Gmt900
I'm waiting for replies from Tekonsha & GM of Canada about the connections for the brake controller harness.
The Tekonsha P3 harness has the following 4 wires:
black
white
red
blue
Apparently the OEM "blunt cut" pigtail has 5 wires:
White
red
blue
orange
blue/white
Can anyone positively tell me which wires on the brake controller harness connect to the proper wires on the under dash harness?
The reason I'm asking is that a friend just had a brake controller installed & the wiring got screwed up. He hasn't been back yet to get it rectified. So I can't check his truck.
black
white
red
blue
White
red
blue
orange
blue/white
on page 2 is a PDF in the HOW TO SECTION at the bottom of the forum.
http://www.gm-trucks.com/forums/index.php?showtopic=68309
im guessing the HDF's arent different, if much at all, in this case.
the orange wire is not used, just taped off and put to the side. not all colors match up with the matching colored line, the PDF has a diagram.
That's a great PDF! I had posted on a RV website & I was linked to a Youtube video. Guy just kind of breezed thru the wiring connections, so I wasn't any further ahead by watching it.
I'll print it off when I go to install the P3.
