What Is With The Silverado's Front Bumper?
I have wondered why some Silverado's have a slit in the front bumper and some do not.
I looked at different years and some have them and some don't in the same year.
Is there any rhyme or reason to this?
I found on the 2011 HD's they are bigger for the oil cooler but that is all I came up with.
Any ideas?
I would like to know, to. I thought it had something to do with the year.
2007-2008 only had them for the models which carried HD cooling. 2009+ all have them.
Actually for '07-'08 on the 1/2-tons only those with the "NHT" Max-Trailering package had the slot,starting in '09 all 1/2-tons have it.
The HD's have always had the slot regardless of year/options.
Thanks, I knew it was something like that.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
