Daytime Running Lights
darthpapa
Help----- i have a 1999 GMC Sierra 350 2wd and my daytime running lights will not "power up" to full power when i turn on the headlights for night driving, but, the high beams do work at full power.
Are you talking about DRLS or the low beam lights on your '99? DRLS usually are "off" when headlights are on unless they have been rewired. I'd begin checking wiring for any grounding or poor connections issues.
