Because they do....? The advertised 6" lift for the GMT-900's nets about 7.5-8" of lift. Not sure about other years.
Yes, I have one and I am very happy with it.
Got about 7.75" of lift out of mine. You can measure the components and see. I cant remember the exact figures but the cross-member measured just shy of 8" and that usually gives you a good idea of how much lift you get with the kit. I think the strut extensions were 7.5 or 8" too I cant remember anymore but all the math added up to just shy of 8"s and thats exactly what i got on fender measurements.
Had 7.5" gain and that was to the bottom of the fender flare, original measurements were without fender flare and it takes up about a 1/4" of an inch below the fender.
Do you run a fabtech if so are you happy with it
Running the same kit and very please and measuring exactly 8". Plan on throwing a 2" body lift on it and rolling with 37". I have a scheduled deployment next year and possibly going to get a 20K re-enlistment bonus tax free which will be more than enough to buy 4.56 gears, the shoes, new wheels, and a bunch of other performance stuff. Damn I cant wait!
Throw some money my way and I'll keep it safe when you get deployed :fume:
Don't believe they make a 2" bl for these trucks...anyway, you need 3".
Ehh you dont NEEED 3 inch you could do 1.5" Body Lift and the 1.5"-2" leveling kit.
Oh and do youself a favor and save some of that 20k please dont blow it all on stupid truck shit that will lose all its value in just a couple years.
Thanks for the info on the body lift and all and trust me I dont plan on blowing all of the money on it, I only get half of that up front and the rest on my yearly anniversary. If anything with the money I make just being deployed, its more than enough to do what I need to do. Going to pay off some debts and take my little ones to Disney World and the old lady on a cruise.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
