1/2" Rear Spacer For 2008 Silverado?
Does anyone know where I can get a 1/2" rear spring spacer for my 2008 silverado ltz. I installed a front leveling kit and would like the rear to sit a little higher.
you just need a bigger block, you have to take out the stock lift block in the back and put in taller one. Ebays got them.
somethin like this. W0QQcmdZViewItemQQfitsZYearQ3a2008Q7cModelQ3aSilveradoQ201500QQhashZitem3ca3b126
12QQitemZ260444333586QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
DO NOT stack blocks EVER. Replace the existing one with a new one that is thicker (to your liking) and make sure to install new Ubolts in the process.
Thanks guys. I was just wondering if anyone had used a certain companys block and where I could find one that was made like the oem for a 1500, 2008 ltz. 2" would be perfect.
How difficult would it be to add another leaf.. give you the lift you wanted (net .75in.), AND strengthen your payload/towing support? Would this not be a better option? or is there more to this than I think?
How much more in $ do you figure?
Only problem with adding a spring is you also stiffen the heck out of the ride.
Blocks are pretty much blocks. As long as they are cast or machined correctly, they pretty much are a universal thing. All they amount to is a solid piece of metal as a spacer.
ahhhhh good point...
Whats a good price for a set of 2" blocks and the new ubolts? There's a place local here... sells them as a kit for like $90.. seems a bit high for just blocks and bolts.. no? And to maintain the stock "tilt"... 2" blocks (replacing the stock ones) and the RC kit would do it? (I tow, and when I'm hooked up, the truck is level.. I'd like to keep that, and not sag in the back)
cast iron blocks or steel would be better. Aluminum can mush out over time if you carry a lot of heavy loads on rough roads
OK got one from ready lift. 2.25" replaces the stock 1.25" and raises the rear up 1" and that works perfect with the bilstein 1500 shocks. Thanks for all the members input. Buy the way, the optima 34r, reversed terminal battery that I have install in my 2008 silverado fits perfect with no modifications.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
