Clearance Lights/ Cab Roof Lights
Gentlemen,
I have a 99 Silverado 2500 (new body style). I would like to install cab roof lights on it. I have seen some light sets available for around 50 bucks plus a wiring kit. Has anybody ever successfully installed them on a truck that did not come with them from the factory? What all does this process entail, i.e. how much cutting am I going to have to do to the roof of my truck, and will I have to remove my headliner as well? If someone has done this, please tell me how and how it turned out, thanks much appreciated.
Got mine from recon.
didn't have them from the factory, all I did was take a few measurements from an hd that had them, made a few marks with a sharpie, color of choice, placed them where i thought they looked good, doubled check measurements then i had a buddy keep each one in place as i drilled a very small hole, not sure of the size, down through each screw opening of the light into the cab. Also, two other small holes the same size as the wires, very thin gauge. Pulled down the upper center console, one screw, and reached in above the head liner to fish for the two light wires. Edit: for the two side lights, before I went fishing for the wires, i extended them and used wire nuts that are stored away in the light itself. Brought all three reds and blacks into one big wire nut along with another power and ground and connected them all together. Fished the power and neg over to the driver side a pillar, down under the dash, went through the firewall through a grommet and down the inner fender with the power and for the neg just found a bolt with a washer on the fender to hook the ground to. Tied my power into my driver side parking lamp, made sure all connections were water tight then used the screws and rubber washers only that came with the lights to sort of self tap in the small holes I previously drilled.
The kit wanted you to drill 1/4 holes almost and I highly disagreed. I didn't want want 10 large holes all through my cab so i went and drilled the smallest ones possible. Make sure they are all nice and snug, don't strip the holes..... Topped everything off with some clear silicon over the screws and around the perimeter of the lights just for redundancy.
That's how I did mine. Is it the end all way to install cab lights, most certainly not but it works for me. Some ask why I didn't tie them into my day time runners, well for the simple fact I don't need them on during the day.
I put some on my 2005 about a year ago. I went with five individual lights which requires alot more drilling. I really like the way they turned out, but if I knew how time consuming it was, I wouldn't have done it. There are several great threads on here that go into excellent detail on how to intall them. I just followed those recommendations. It took me about four hours for install, but I measured everything like five times before I drilled. That was the time consuming part. I could probably do it in half the time now. Working under the headliner splicing wires together wasn't much fun but you don't have to remove it. I used masking tape to hold everything down after I had the lights where I wanted them. First hole was the hardest to drill. I was thinking "what the heck am I doing". Just take you're time and don't rush it. You may want to use a drill stop on the bit so you don't go thru the headliner. I siliconed under the lights and around the lights after I was finished so I knew water wouldn't creep in. To date I've never had a problem. It's a doable project just takes time.
old school looking, i dig it.
Yeah I kind of wanted to look different than everyone else. These lights happen to be the LED's and they look pretty killer at night.
Also to add because i will be doing this soon, on the passenger side of the dash there is a panel like the fuse panel on the driver side. open that up and you find an empty slot with two prongs. That's where the cab lights hook in from the assembly line and will only turn on when your parking lights or headlights are on. And where did you find them for 50 bucks??? carbarn.com has the 01-07 factory ones for 70 bucks and the 07.5-current ones for 110 thats the cheapest i've found.
http://www.gorecon.com/product.php?pk=308&...02&p_cat=30
http://www.buyautotruckaccessories.com/pro...-led-light-kit/
These are the older style, but I actually prefer it to the newer 3 light style.
I've been debating on adding a set to my truck, but I have been having a hard time deciding if they would look right. I think they would look very good on a CC, or EC but my regular cab I'm not sure. Need to look at some more pics.
I plan on going with either the 3 piece factory looking style, or the recon 3 light skinny led set. I'm leaning towards the skinnier one, to help appearance while not on.
Does anyone see a problem with adding the 07-10 recon lights on my 96?
I thought I had a pic of my '94 regular cab that had the UO1 lights, but can't find any.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
