Gmt900
any tricks to get the trim around the switches out of the door!!
i've tried and i do not want to break anything!!
Thanks
Thanks
They are only held in with clips. Here are some picks on the bottom of the switch trim when I pulled them out of my denail. Hopefully this will help you pry out where the clips are located. I took a screw drived wrapped in electrical tape and place it unter the rolled edge and lifted it that way. You can see there is only 2 clips one at each end. Hope this helps.
