How To Stop Rear Locker?
If I do a u turn on a paved road sometimes I spin a wheel on the dirt shoulder and the rear differential locks. Any trick to unlocking it before I complete the turn? Just don't like putting all the stress on it. Kinda cool to squall the inner tore at 1 MPH though.
Good call. When I turn I end up going down the ditch incline and there is no weight on the inside tire so it spins. Just wondered if backing up would unlock it. Usually I do a reverse 3 point turn but some situations call for a u.
Maybe u-turns call for 4wd. :( Reverse might actually unlock it, but it's not hurting it to stay locked. The way I look at it, you mght as well burn rubber as often as you can and as long as you can afford to, because life is supposedly short. :rolleyes:
if it makes you feel better i put the right wheels onto some gravel and left wheels on pavement, gave her some onions, felt the locker kick in and layed a black strip down the road and a groove in the gravel on the other side :rolleyes:
another option you have is to remove the factory locker and replace it with an e locker or even an air locker. that way you have control over when it does and doesnt engage :rolleyes:
it's functioning as designed.
learn to keep all of the wheels on the pavement and the problem won't exist. a truck turns way wider than a front wheel drive car, keep the turn wide so that the inside tire doesn't fall off into the ditch, don't apply quite so much accelerator pedal and it won't do that.
X2 only problem i have when mine does this is that I cant make the U turn then. Maybe its not as big of a problem in a truck with the lighter rear end but in a Yukon it makes it really hard to turn around.
Also backing up wont get it to unlock for me.
Keep the truck on pavement? What fun is that? All you need to do is kill the traction control and stabilitrak and you'll be fine.
Not making fun i just find this thread funny. I don't know why, but i do... Usually we complain about the opposite. when the truck does what it should we should be happy..
check you tube vids on the G80, just type it in, G80 locker and watch the fun, shows the difference between all the rears in these pickups, different tests, models, etc. GM has the right rear in their trucks/SUV's...
My denali has a G80 locker inthe rear, in the sand/snow anyone that criticizes the "AWD" not selectable 4wd in the Denali pickups/Yukons take note. the AWD system in these trucks coupled with that G80 is what makes it as good as any 4WD system out there. I did alot of research before switching to the Denali from the Tahoe in the $wd vs AWD area and I was overly satisfied by both reading the articles and comments from other owners that made the switch to AWD. In the case of the OP, the AWD system in an SD would quell your major complaint lol..
